fkuser_104673
Nov 20, 2009Logging succesfull web UI loggin attemps
It's possible to log the correct access to the web UI. I've checked the /var/log/secure but only ssh success logins are recorded.
Changing the database value Log.Auth.Level to debug intead of error, but it not appears to have any effect. Do I need to restart any process?
Thanks!
- hoolio
- fkuser_104673
I think it was not possible, as SOL said:
In BIG-IP versions 9.4.2 through 9.6.1, only command line transactions are logged, and all messages are logged to the /var/log/secure file.
I seems like successfull Configuration Utility authentications aer not logged
Thanks again - hoolio
I think you're correct that in pre-v10 there isn't a supported method for logging GUI login attempts or successes.
Though, you can kind of infer successful logins by checking the /var/log/httpd/ssl_access_log for entries like this:
Nov 27 09:23:38 ltm_hostname logger: [ssl_acc] 172.31.42.24 - my_user_name [27/Nov/2009:09:23:38 +0000] "GET /tmui/tmui/system/settings/redirect.jsp HTTP/1.1" 302 -
This would only work for identifying logins where the user accesses the root document and is redirected to /tmui/tmui/system/settings/redirect.jsp.
Aaron
