Jeff_Knights_44
Dec 06, 2012local HTTP auth looping? HELP!!!
I recently built a simple irule to do a local HTTP authentication from a datagroup which would block the public from seeing a beta website.
I have watched the logs and it says "User XXX has been authorized to access virtual server /Common/TEST_SERVER
so it seems the irule is working correctly but the website never comes up, the userid and password screen keep coming up as if in a loop. any suggestions?
here is the irule:
binary scan [ md5 [HTTP::password]] H* password
if { [class lookup "[HTTP::username]" datagroup_xxx] equals $password } {
log local0. "User [HTTP::username] has been authorized to access virtual server [virtual name]"
Insert iRule-based application code here if necessary
if { [string length [HTTP::password]] != 0 } {
log local0. "User [HTTP::username] has been denied access to virtual server "
HTTP::respond 401 WWW-Authenticate "Basic realm=\"local.loc\""
- hoolio
Hi Jeff,
Can you try this?when HTTP_REQUEST { if {[HTTP::password] eq ""}{ HTTP::respond 401 WWW-Authenticate "Basic realm=\"local.loc\"" } else { binary scan [md5 [HTTP::password]] H* password if { [class lookup "[HTTP::username]" datagroup_xxx] equals $password } { log local0. "User [HTTP::username] has been authorized to access virtual server [virtual name]" Insert iRule-based application code here if necessary } else { HTTP::respond 403 content "blocked!" } } }
Aaron - Jeff_Knights_44
it came back with:
The website declined to show this webpage - Jeff_Knights_44
and the F5 logs showed:
User XXX has been authorized to access virtual server /Common/XXXXXXXXXX - hoolio
If you take the iRule off of the virtual server are you able to access the pool?
i just noticed something, the second time the userid/password auth screen comes back is says something about "Sling (Development)" which is not us. - Jeff_Knights_44
yes, if you take the irule off it goes where it should... one of our websites - Jeff_Knights_44
can you see an attachment i just attached ? - Jeff_Knights_44
can you see this attachment?
- Jeff_Knights_44
ok, one more time...
- Jeff_Knights_44
I am quickly thinking everything is working as it should but the website sees the AUTH request and somehow the JAVA on the site is reacting...
