aabhiaabhi_3357's avatar
aabhiaabhi_3357
Jul 09, 2018
Load balancing Weblogic T3s connections
We are implementing t3s load balancing over LTM. The client and servers are both weblogic and communicate via t3s protocol. Its a JMS queue based implementation. The VIP at LTM is created on 8443 port and the server pool members are listening on 7011, 7012 and 7013 respectively. The pool members are basically weblogic managed server running on same IP address.
When client try to connect to server via LTM VIP, the client gets below error "The JMS store-and-forward (SAF) forwarder failed to connect to the remote destination "t3s://10.39.5.141:8443/QueueName". but if try to connect directly to pool member the connection from client to server gets established. Client has SAF configured to communicate to LTM
When the connection is tried via LTM, we can see client communicating to LTM and from LTMto server connection is not established.
Thanks, Abhishek
