SSHSSH_97332
Jan 14, 2012Load Balancing to Casches
i need to implement the below 2 functions with LTM to load
balance
to Cache servers :
will all of that be done using IRules ? will it be one Irule or three ? Can you help me with examples
- nitass
Employee
are you using v10? if so, just wonder why you do not just use built-in carp.
sol11362: Overview of the CARP hash algorithm
http://support.f5.com/kb/en-us/solutions/public/11000/300/sol11362.html - SSHSSH_97332
Thanks , does this achive Top Domain selection ?
also it mentions the Irule :
persist hash [HTTP::uri]
This persists based on the URI , my target is to persist based on the site ( all tarffic of youtube to go to same cache ........ ) , what is the IRule for that ? - nitass
Employee
you can use [HTTP::host] instead of [HTTP::uri]. - SSHSSH_97332
Thanks alot , what about meaning / benefit of " Top Domain selection" ? - nitass
Employee
i guess you mean to load balance by using part of FQDN. if so, yes it is possible. you can specify any part of FQDN when doing CARP i.e. replace [HTTP::host] with whatever you want.
