Angelo
Feb 20, 2013load balancing printer traffic
Hi
I have a fastl4 VS with two print servers in the backend pool. the problem is i can access the print servers on port 445 but i can't install a printer. if i connect derectly to the backend it works fine. i also have a folder with drives on the same server that i can access copy install from without a problem so i can't see what i am missing..
- Angelo
Got it working if anyone is interested this is how i did it...
VS configuration on F5
ltm virtual vs_bc_printing {
destination 10.237.0.1:any
ip-protocol tcp
mask 255.255.255.255
partition BRC
persist {
/Common/source_addr {
default yes
pool pool_bc_citrix_printers
profiles {
FastL4_Print { }
rules {
LB_logging
snat automap
translate-port disabled
vlans-disabled
In conjunction to this a loopback adapter will need to be created on the Wintel server (no reboot is required for this setup and the commands must be run to activate the adapter..)
Click Start, select Run and enter hdwwiz to start the Hardware Installation Wizard
When the Wizard has started, click Next
Select 'Install the hardware that I manually select from a list (Advanced)', click Next
Select 'Network adapters', click Next
Select 'Microsoft' & 'Microsoft Loopback Adapter', click Next
1. Right click network icon in the systray and click Network and Sharing Centre
2. Click Change adapter settings
3. Right-click the new loopback adapter and select Properties
4. Un-check all items except Internet Protocol Version 4 (TCP/IPv4)
5. Select Internet Protocol Version (TCP/IPv4), click Properties and configure the IP address to be the same as the Virtual Server (VIP), with a full subnet mask of the individual IP e.g. 255.255.255.255. Do not add a gateway.
6. Click OK on the TCP/IP popup window, then click Close on the Local Area Connection window to save the new settings For Windows 2008, its not necessary to modify the interface metric on the advanced tab and should be left set to Automatic
8. Rename the loopback "Loopback" from localareaconnection 2
9. Run the following in a command prompt:
netsh interface ipv4 set interface "Local Area Connection" weakhostreceive=enabled
netsh interface ipv4 set interface "Loopback" weakhostreceive=enabled
netsh interface ipv4 set interface "Loopback" weakhostsend=enabled
10. Now repeat the above process for all other Windows 2008 real servers
