Jason_19901
Jan 10, 2014Load Balancing Print Servers using Create Form (Bottom Line Technologies)
Working on a project where I looking for a way to LTM print servers that use create form and create stream. Those are two products in the Bottom Line technologies suite. It seems to be a very sensitive print program where the print job is directed to a specific printer.
- BinaryCanary_19Historic F5 AccountI think you need to describe your problem a bit better...
