SSHSSH_97332
Oct 31, 2012Load Balancing From Radius
we will use F5 to load balance accouting packtes from Radius server to database servers .
the issue is that Radius may send accouting packets with same source port ( ie : same src & dst ips , same src & dst port ) to F5 VIP .
F5 will drop this considreing this as duplicate packets or what ?
- What_Lies_Bene1
Wouldn't the same src and dst ip and port be used in most IP communications, RADIUS or otherwise? - SSHSSH_97332
Radisu server sends accounting packets to database servers ( to VIP on F5 containing pool of databsae servers ) .
the idea is that Radius server may send same packet ( same l4 headers ) mutiple times - What_Lies_Bene1
Just out of interest, why would it do that? Regardless, I think the only way to find out would be to do a test and monitor with tcpdump. I'd be keen to know what the result is. - SSHSSH_97332
Thanks , my traffic is in production si i may need a downtime .
does the below says that F5 will not drop UDP duplicate packets :
http://support.f5.com/kb/en-us/solutions/public/3000/600/sol3605.html - What_Lies_Bene1
Understood. The article isn't too explicit but this is: http://wiki.wireshark.org/DuplicatePackets - doesn't look like you have a problem although you might need to use the feature described in the article you listed.
