sreenivas_mr_87
Feb 12, 2010Load Balancing BizTalk MLLP adapter using F5
We use F5 in our organization for load balancing web servers.
We would like to use the same for load balancing the BizTalk servers.
We use the MLLP adapter to work with HL7 messages. As per the documentation from microsoft, MLLP adapters will not work in a BizTalk cluster unless there is a virtual IP configured.
Do anyone of you have documentation on how to setup the virtual ip to make the MLLP adapter work on the BizTalk cluster.
This is pretty urgent requirement and any help is appreciated.
Thanks and Regards,
Sreenivas
- Dr_Peter_J_Sant
Sreenivas
I was wondering what solution you took to make the MLLP adapter work in a clustered environment?
Peter
