Load balanced -Observed with persistence
I inherited a F5 with a VIP using Observed(members) as a load balance method. this VIP also has persistence profile with sticky Destination Address Affinity
I am seeing that all the traffic is only going to 1 of the servers in the pool. ( There are 3 members) is this persistence profile causes this? how to I correct it.
thanks and all help is appreciated.
-Will
- gsharri
Altostratus
Yes, it seems the persistence profile is directing all traffic to a single pool member. What kind of hosts are in the pool? Are they application servers the clients are connecting to or are the pool members providing network pathways (routers, firewalls)?
- William_Lampen_
Yes, Web App servers.
- gsharri
Altostratus
You'll need to change the persistence method. Destination address persistence will send all traffic for a given destination (in this case the vip) to a single pool member. You likely want to load balance clients across pool members and then have them persist to the member choosen in which case you need a persistence profile that identifies a returning client (as opposed to identifiying the destination for the traffic). Source address and http cookies are the most common methods for this type of persistence.
- William_Lampen_
thank you, I will test this and verify it works with our environment.
