Load Balance Oracle Customer Care & Billing(CCB) Problem
Our company load balance our critical applications with F5 BigIP appliances. We are experiencing server workloads not evently balanced. The F5 Virutal Server for CCB was configured based on F5 recommended configuration for weblogic (http://www.f5.com/pdf/deployment-guides/bea-weblogic-big-ip-v10-dg.pdf).
I have noticed that CCB Virtual server current connections does not match CCB Pool current connections. Pool have fewer connections than VS.
How do I confirm F5 distribute users evently between pool members. Based on Weblogic logs users are not well balanced between each node.
- Should I keep using Oneconnect?
- How this will affect Weblogic performance?
- Anything else to consider?
Thanks,
ARod
