chabakro's avatar
chabakro
Dec 02, 2020
load balance based on payload data
I need your help to do a "custom L7 load balancing" :
we are using F5 LTM to load balance a proprietary protocol and we would like to redirect some requests that contains a specific string to a different server/pool,
is this something we can do with irules ?
can we use Message routing framework (MRF) to achieve this ?
thank you
  • These kind of senerio not seen but try MRF and update us also.. thanks​
  • can something like this work ?
    when CLIENT_ACCEPTED {
      TCP::collect 100
     when CLIENT_DATA {
      set payload [TCP::payload]
      if { $payload contains "magic" } {
       pool magic_pool
       pool default_pool
  • Something like that might work, but only if the TCP payload is in clear text and not encrypted, as with SSL/TLS.
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
      As long as SSL Offload is there, it should be doable I believe. Like below code snippet Ive shared.
  • I'd try something like below, have done payload manipulation in the past, so i assume it should work.
    Keep us posted/.
    ltm rule test_rule {
    set ltm_trace [string range [AES::key 256] 15 23]
    set vip [findstr [virtual name] "" 8 ]
    log local0. "LTM_TRACE=$ltm_trace VIP=$vip CLIENT=[IP::client_addr] has established a connection"
    when CLIENTSSL_HANDSHAKE {
    SSL::collect
    when CLIENTSSL_DATA {
    # Do not log fullpayload as it may contain sensitive information
    #log local0. "LTM_TRACE=$ltm_trace VIP=$vip FULLPAYLOAD=[SSL::payload]"
    if { [SSL::payload] contains "magic" } {
    pool magic_pool
    log local0. "LTM_TRACE=$ltm_trace VIP=$vip --> Pool=magic_pool"
    pool default_pool
    log local0. "LTM_TRACE=$ltm_trace VIP=$vip --> Pool=default_pool"
    SSL::release
    when CLIENT_CLOSED {
    log local0. "LTM_TRACE=$ltm_trace VIP=$vip CLIENT=[IP::client_addr] connection is closed"
