Pratik_125797
Dec 18, 2012Lists not appearing in Sharepoint when behind F5
When I put share point behind F5 any kind of list does not appear. It gives an error "list deleted by another user". But when I access the server directly, it works perfectly fine.
Has anybody encountered such error ?
- What_Lies_Bene1
Can you supply the SP and F5 software versions please. Also, are you using the F5 to offload SSL? IS AAM configured on SP?
I'm sure I've seen this issue before but I can't find anything now; I'm sure it was to do with Cache Control headers or something similar. Have you read through the documents here: http://www.f5.com/products/technology/microsoft/sharepoint-server/ - El_Jefe
If you are on BIG-IP v11.x, make sure you are using the latest greatest iApp.
Jeff
