Tiaan_92076
Apr 19, 2009Link Redundancy on Cisco Switches
Hallo,
I need to connect a Big-IP device to two physical switches for redundancy. I don’t want the Big-IP to take part in the spanning tree, one of the reasons being the Cisco’s are using the PVST protocol. The Cisco’s are not clustered therefore EtherChannel will not work across the two switches. The Big-IP will also be doing VLAN Tagging on these links.
I need the Big-IP to be on standard access ports and not be a bridge.
I’m not able to find any documentation on how to set this up, any help would be appreciated.
Diagram attached.
Tiaan
- Tiaan_92076
Hallo,
We tested the following and it seems to be working correctly.
Spanning tree was disabled on the Big-IP. A trunk containing the two ports was created without LACP configured. VLANs was then created with the VLAN tag number configured on the trunk interface as tagged. Self IPs was added to the VLANs created above.
The Cisco ports was left as access ports with VLAN tagging.
Am I correct in saying the Big-IP will not be a bridge in the above configuration ?
Tiaan - x86brandon_9930
If you have the port density on the BIG-IP, you could use access ports/port based VLAN's on untagged interfaces tied to specific VLAN's on the F5.I am having same problem. My secondary link is going in loopguard and never recover
