Ken_Wong_48678's avatar
Ken_Wong_48678
Historic F5 Account
Sep 30, 2005
limit client connection
Hi guys,
Is it possible using irule to limit number of connections from each client ip address?
If yes, pls. give me some samples how to do it. Thanks!
Regards,
Ken
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    That's a great question, and one we've seen before.
    Here's a great post made a little while back that explains this, and gives a good example of the code.
    Click here - http://devcentral.f5.com/default.aspx?tabid=28&forumid=5&postid=1674&view=topic
    -Colin
  • Ken_Wong_48678's avatar
    Ken_Wong_48678
    Historic F5 Account
    Hi Colin,
    I have tested the following irule and it can sucessfully to check the number of connections. However, it cannot reject the connections more than 5.
    I opened a few browsers to access BIG-IP vip, i see the log show "Client $client_ip has too many connections" after the connection greater than 5. But, when I open additional browser to access the vip, it still can access the server. Based on my understand, the rule should block the sixth connection from same ip address. Is it true? Thanks!
    when RULE_INIT {
       array set ::active_clients { }
       log local0. "phase1"
     when CLIENT_ACCEPTED {
       set client_ip [IP::remote_addr]
       if { [info exists ::active_clients($client_ip)] } {
         if  {$::active_clients($client_ip) > 5 } {
           log "Client $client_ip has too many connections"
           reject
           return
           log local0. "$::active_clients($client_ip)"
           incr  ::active_clients($client_ip)
         set ::active_clients($client_ip) 1
     when CLIENT_CLOSED {
         incr ::active_clients($client_ip) -1
         if { $::active_clients($client_ip) <= 0 } {
           unset ::active_clients($client_ip)
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    I think the problem with your iRule is that after doing the "reject" command, the CLIENT_CLOSED event is still evaluated. So, the active_client count is decremented even though it wasn't incremented by this connection. So, you should move the "incr ::active_client($client_ip)" line to before the check for > 5. That way the current connection will be counted and then decremented after being reset.
    unRuleY_95363
    Historic F5 Account
    Another way to handle this would be to disable the CLIENT_CLOSED event when you do the reject. You can do this by adding the command "event CLIENT_CLOSED disable" before the "return" where you reject the connection.
