LDAP Monitor Debug
Folks,
I've been looking over a few posts that have mentioned LDAP monitors to understand the DEBUG option. I've enabled DEBUG on a couple of LDAP monitors because there are intermittent log entries suggesting that a pool member is failing their health checks. Unfortunately for me, the monitor is communicating through SSL so I can't just do a sniff to see what's happening. I foolishly thought that using DEBUG might proffer an insight.
Here is the configuration of the monitor (details changed to protect the guilty):
ltm monitor ldap e7_server_ldaps {
base cn=healthcheck,cn=localhost
chase-referrals no
debug yes
defaults-from ldaps_template
destination *.10636
filter (&(objectclass=healthCheck)(isalive=true))
interval 30
mandatory-attributes yes
partition Common
password letmein
security ssl
time-until-up 0
timeout 1
up-interval 60
username cn=e7healthcheck,ou=servers,dc=com
With debug turned on, this is the style of output that I'm getting:
********** Debugging session beginning at: Wed Oct 1 14:26:08 2014
Arguments 1-2:
::ffff:1.1.1.1
10636
Environment variables:
BASE=cn=healthcheck,cn=localhost
CHASE_REFERRALS=no
DEBUG=yes
FILTER=(&(objectclass=healthCheck)(isalive=true))
MANDATORYATTRS=yes
MON_TMPL_NAME=/Common/e7_server_ldaps
NODE_IP=::ffff:1.1.1.1
NODE_PORT=10636
PASSWORD=letmein
SECURITY=ssl
USERNAME=cn=e7healthcheck,ou=servers,dc=com
Host URL: ldaps://[::ffff:1.1.1.1]:10636
********** Debugging session beginning at: Wed Oct 1 14:26:38 2014
Arguments 1-2:
... and so on.
What I thought the DEBUG was going to offer was what the pool member returned. But as it stands, the health check has been failing consistently for the last couple of hours and not a hint from the DEBUG.
Other than turning off SSL so I can see the plaintext in a sniff, is there something I'm missing with the DEBUG? Is there something else I can do to see what the specific issue is?
Timothy
- Ian_Mahuron_383Historic F5 Account
The LDAP monitor's debug messages tend to be on the negative side. That is, they accompany hard errors and there are very few informational messages. In fact, you're seeing one of the few informational messages, "Host URL". In this particular case, no news is good news. You can safely assume that a request was sent and the response was handled. If I were to take a guess, I'd say the LDAP server send back no results, thus no "Up".
Try simulating your query using ldapsearch from the TMOS command line. It may provide some insight as to why your monitors are failing.
