Austin_Geraci_1's avatar
Austin_Geraci_1
Jul 14, 2006
LDAP iRule-anyone out there using LDAP to monitor?
Is anyone authenticating using LDAP for a monitor? I need some insight into the iRule to do so.
Thanks!
  • hoolio's avatar
    hoolio
    Hello,
    The LDAP monitor on the BIG-IP allows you to specify a username and password as well as encryption options. Check out the latest LTM configuration guide for details:
    Click here
    Or do you have a special requirement to use a rule?
    Aaron
  • Thanks, I've since located EAV monitors, for some reason Support sent me down a rathole and infered I needed an iRule to do this.
    Thanks again!
    Do you know anything about my RMI question I have out there?
