launch tcpdump and custom parameters with REST
Would it be possible to make a REST(ful) API call to launch a tcpdump with custom parameters (if we prior configure an alias in TMSH)?
Alex
- amolari
any iControl expert could help here please? Hi,
You could do something like the following:
curl -H"Content-Type:application/json" -kv -u admin https://localhost/mgmt/tm/util/tcpdump -X POST --data "{\"command\":\"run\",\"utilCmdArgs\":\"-i0.0 -C10 -s0 -w /var/tmp/test.pcap host 20.113.206.28\"}"A fairly large problem with this, however, is that the tcpdump process will just keep running. The REST call exits eventually with a timeout, because I expect that the system expects the command to start up, run for a few seconds at most, and quit. I ended up having to kill the tcpdump process as well as the parent process, icrd_child.
I don't feel that running tcpdump directly via the API is supported or a great idea. Hopefully someone else has some thoughts on how to best achieve this remotely. Definitely test this thoroughly in your lab if you want to continue.
Thanks, Josh
