Josh_Hill_17083's avatar
Josh_Hill_17083
Apr 18, 2010
JSESSION ID Login Issue
I am attempting to integrate LTM with a web application that uses a cookie based jsessionid somehow during the login process that the F5 is not handling.
To explain, when I browse to the site through the F5, with cookies turned off in my browser, I can see a jsessionid parameter in the address field, and can log in.
When I switch cookies back on in my browser, I no longer see the jsessionid in the address field, but when I attempt to login to the application, the browser is redirected back to the login page.
When I try the same process while browsing directly through to the node, the login works with or without cookies enabled.
There is only one node so I dont believe it is a persistence issue. Any help would be greatly appreciated.
Cheers
Josh
  • hoolio's avatar
    hoolio
    Hi Josh,
    It would help to identify what's different when you're testing through LTM compared with direct to the application. Are you offloading SSL on LTM and using cleartext to the pool member? Are the VIP and pool member defined on different ports?
    You can use a browser plugin like HttpFox for Firefox or Fiddler for IE to record the HTTP requests and responses when it's failing through LTM. If the issue is not readily apparent you can compare the failure scenario with the working logs taken on tests direct to the application.
    Aaron
