Jeff_42378
Aug 02, 2010Issues with SNAT configuration
Currently we have a co-existence of OCS 2007 R2 and LCS 2005, both behind the same F5. Our F5 team had setup an iRule for SNAT because I guess there were issues moving users from LCS to OCS. Basically, we are seeing errors on our FE servers where traffic is trying to be sent to the SNAT address on the F5. Is there any recommendations on co-existence of LCS/OCS behing the same F5 on the same subnet?
- hoolio
Hi Jeff,
What are the symptoms of the problem? Are responses from the servers failing to reach the clients? Or is it traffic originating from the servers which should be routed through LTM that's failing?
What is the iRule doing? Are you using separate SNAT addresses for the different virtual servers?
Aaron
