awakenings's avatar
awakenings
Jul 14, 2022
Issues to forward requests with 'start with' due to similar contexts under same domain
Hi everybody,
A network request that seemed to be simple is giving some trouble to our network team, I'd appreciate some help.
Here's a summary of the rules to be put in place:
1) example.domain.com/cali --> forward to server1
2) example.domain.com --> forward to server2
When creating the rule with "URI starts with" from web interface it works, but there's a side effect: requests like example.domain.com/california are matching rule 1) and therefore failing, since that context is managed by some Apache at server2.
They've tried using 'IS' instead 'STARTS WITH' for /cali but then, when trailing slash is not added, it fails. It also fails when calling something like /cali/ad
Since we don't know what other possible contexts might be requested, we want just to add a rule for /cali and leave everything else (/california , /calisthenics, ...) under rule 2)
What's the issue here? Is something like it possible just using the web interface or are iRules needed? Any examples?
Thanks a lot in advance
  • Hi awakenings ,
    you might use the regexp, but using globbing is probably less CPU intensive:
       # Check the requested path (set to lowercase)
       # -glob: allow string pattern matching
       switch -glob -- [string tolower [HTTP::path]] {
          "/cali" -
          "/cali/" -
          "/cali/*" {
             log local0. "Matched pool 1 paths for [HTTP::uri]"
             pool pool1
          "/california" -
          "/california/" -
          "/california/*"  {
             log local0. "Matched pool 2 paths for [HTTP::uri]"
             pool pool2
          default {
             log local0. "Hit default for [HTTP::uri]"
             pool pool_default
    This will send traffic to /cali and following segments to pool1 while traffic to /california and following segments will be forwarded to pool2.
  • In case you want to consider multiple URLs for content switching I would recommend using a switch statement with globbing und a non-case sensitive lookup of the URI path.
    Using the switch statement is described here: https://clouddocs.f5.com/api/irules/switch.html.
    Make sure to use OneConnect, to be able to differentiate between requests in the same KeepAlive connection.
    • awakenings's avatar
      awakenings
      UPDATE: I just realized I can add just /cali and that should be it
            "/cali" -
      "/cali/*" { log local0. "Matched pool 1 paths for [HTTP::uri]" pool pool1 } default { log local0. "Hit default for [HTTP::uri]" pool pool_default } } }
      Thanks a lot! 🙂
      • And if you prefer using regexp for even better granularity you can try this:
            switch -regexp -- [HTTP::path] {
                "(?i)^/cAli(|/|/.*)$" {
                    # log local0. "[HTTP::path] matches /cali and sub segments"
                    set response_string "[HTTP::path] matches /cali and sub segments\r\n"
                "(?i)^/califOrnia(|/|/.*)$" {
                    # log local0. "[HTTP::path] matches /california and sub segments"
                    set response_string "[HTTP::path] matches /california and sub segments\r\n"
                default {
                    # log local0. "[HTTP::path] not matches regexp"
                    set response_string "[HTTP::path] not matches regexp\r\n"
            HTTP::respond 200 content "${response_string}" noserver Connection Close
            unset response_string
            return
        It is:
        • case insensitive: '(?i)'
        • matching the whole path: '^' to '$'
        • looking for specific segment and sub-segments: '(|/|/.*)'
        • responding directly for testing purposes by using HTTP::respond
        It is important to notice the difference of applying the functions of HTTP::path, HTTP::uri, HTTP::query.
