Bharani's avatar
Bharani
May 21, 2019
Issues in Configuring HTTP health monitor with a non-default route domain Alias.
While configuring the HTTP health monitor, I'm giving the Alias Address as 10.88.52.58%1586. I do not have the default route or specific route to 10.88.52.58 in the default route domain. However I have the default route in route domain 1586 and this server is pinging using this route domain. #HealthMonitor
However when I use this as alias address, the health monitor fails. #RouteDomain
  • Hi,
    I'am not sure that you have to specify rd in " Alias Address" (health check).
    Normaly, health check use route domain of pool member specify in the pool where you set your monitor...
    otherwise confirm that rd that you set in your Health check is the same as the RD that is indicated in your pools memebers in the pool where you set your monitor...
    regards
  • Thanks Youssef! Here I'm applying this health monitor on the node specific monitor directly. Both node is in the same RD as I mentioned in the health check monitor.
