Issue with URI rewrite
Hi Guys,
Having some issues on a rewrite rule I'm trying to create (sorry first time looking at these)
I am trying to copy a rule we have in apache at the moment.
RewriteCond %{HTTP_HOST} ^support.yourdomain.com$ [NC]
RewriteRule ^/(.*)$ https://support.3rdpartywebsite.com/$1 [P,L]
So when our users enter support.yourdomain.com it goes off to support.3rdpartywebsite.com I am assuming and want the end user to not know that support.3rdpartywebsite.com URL and hit it direct.
This is what I have so far but it dosent seem to work any tips?
if { [HTTP::uri] equals "support.yourdomain.com" } { HTTP::uri "https://support.3rdpartywebsite.com" } }
Thanks R
- Mark_van_D
Hi R,
My suggestion would be to look at using the ProxyPass irule.
https://devcentral.f5.com/wiki/iRules.proxypassv10.ashx
- nitass
Employee
if you just want to change http host header in request only, you can use HTTP::header replace command but if support.3rdpartywebsite.com is also embedded in response body (so, you have to rewrite it back to support.yourdomain.com), you may need to use proxypass which Mark suggested.
e.g.
config root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.24.10:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } vs-index 19 } root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } } } root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux ltm rule qux { when HTTP_REQUEST { if { [HTTP::host] eq "support.yourdomain.com" } { HTTP::header replace Host "support.3rdpartywebsite.com" } } } trace [root@ve11c:Active:In Sync] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.24.1(53863) <-> 172.28.24.10(80) 1427071308.3080 (0.0279) C>S --------------------------------------------------------------- GET /someting HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Accept: */* Host: support.yourdomain.com --------------------------------------------------------------- New TCP connection 2: 200.200.200.14(53863) <-> 200.200.200.101(80) 1427071308.3122 (0.0030) C>S --------------------------------------------------------------- GET /someting HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Accept: */* Host: support.3rdpartywebsite.com ---------------------------------------------------------------
