mmelber14_62984's avatar
mmelber14_62984
Sep 19, 2012
Issue with Source based redirection when more than one subnet is added
A background on the situation.
We are running a warehouse management system that requires the telnet protocol to use different ports on the backend server for each "warehouse" or location. We have handhelds that utilize a terminal emulator for this telnet service. The application cannot differentiate the particular ports so we are using the F5 to redirect on a source based irule to a specific pool that contains the back end port.
When we have more than one subnet within the rule, the rule seems to not redirect properly. If we specify only one subnet to pool mapping the rule works as we can see the handheld is able to login to the correct warehouse through the correct port.
Can someone please look at this rule and see if there are any syntax issues. If there is a more efficient way to handle this situation we would like to understand that as well. Anyone's help is appreciated!
iRule:
when CLIENT_ACCEPTED {
if {[IP::addr [IP::client_addr] equals 10.21.72.0/24]}{
pool WMS_APP_DEV_TELNET}
if {[IP::addr [IP::client_addr] equals 10.22.29.0/24]}{
if {[IP::addr [IP::client_addr] equals 10.23.68.0/24]}{
pool WMS_APP_DEV_TELNET_4506}
if {[IP::addr [IP::client_addr] equals 10.22.189.0/24]}{
{ drop }
Thanks,
Megan
  • nathe's avatar
    nathe
    Megan,
    Using the Switch cmd will be more efficient and may sort your issue too.
    See the following for info:
    https://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/108/iRules-Optimization-101--01--if-elseif-and-switch.aspx
    Hope this helps,
    N
  • nathe's avatar
    nathe
    Megan
    Had a bit of time so thought I'd post my suggestion, nowhere near an LTM at the mo so can't fully test, hope it's right though.
       switch [IP::addr [IP::client_addr]] {
         "10.21.72.0/24" -
         "10.22.29.0/24" { pool WMS_APP_DEV_TELNET }
         "10.23.68.0/24" -
         "10.22.189.0/24" { pool WMS_APP_DEV_TELNET_4506 }
         default {
        drop }
    HTH,
    N
  • hoolio's avatar
    hoolio
    You can't actually use a switch statement to evaluate subnets. The original if/elseif/.../else iRule should work. If that's not working you could add debug logging to each condition and check the logs in /var/log/ltm.
    It would be more efficient to add the subnets and pool names to an IP address data group and use the class command to perform the lookup:
    https://devcentral.f5.com/wiki/iRules.class.ashx
    Aaron
  • nathe's avatar
    nathe
    Aaron,
    That's interesting, I'm forever learning.
    What if we use glob and 10.21.72.* etc. instead?
    Thanks as always,
    N
