issue with irule editor and "properties" feature
I've encountered this error when I use the feature "properties" :
System.FormatException: Le format de la chaîne d'entrée est incorrect. à System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) à System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt) à System.Double.Parse(String s, NumberStyles style, NumberFormatInfo info) à iRuler.Dialogs.iRuleInfoDialog.refreshStatisticsLTM() à iRuler.Dialogs.iRuleInfoDialog.refreshStatistics() à iRuler.Dialogs.iRuleInfoDialog.comboBox_Metric_SelectedIndexChanged(Object sender, EventArgs e) à System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) à System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value) à iRuler.Dialogs.iRuleInfoDialog.iRuleInfoDialog_Load(Object sender, EventArgs e) à System.Windows.Forms.Form.OnLoad(EventArgs e) à System.Windows.Forms.Form.OnCreateControl() à System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) à System.Windows.Forms.Control.CreateControl() à System.Windows.Forms.Control.WmShowWindow(Message& m) à System.Windows.Forms.Control.WndProc(Message& m) à System.Windows.Forms.ScrollableControl.WndProc(Message& m) à System.Windows.Forms.ContainerControl.WndProc(Message& m) à System.Windows.Forms.Form.WmShowWindow(Message& m) à System.Windows.Forms.Form.WndProc(Message& m) à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
everybody can help me ?
- IanB
Employee
In English, that error appears to be "The input string format is incorrect". It appears to be trying to convert a string to a number, and finding something that's not convertible. What were doing when you received this error ?
