Girishf5_387421's avatar
Girishf5_387421
Apr 04, 2019
Issue in xml based http Irule
HI...while configuring the irule xml based http .we are facing some issue
Irule :- when HTTP_REQUEST { set capture 0
if { [HTTP::header exists Content-length] and [ [HTTP::method] equals "POST" }]
    set capture 1
    HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
if {$capture} {
if { [HTTP::payload] contains "UE" } {
log local0. "Logs: triggered wanted pool" pool WEBRTC_POOL }
} else
    pool PUSH_POOL
Error:- 01070151:3: Rule [/Common/hi] error: /Common/hi:5: error: [parse error: PARSE missingBracket 86 {missing close-bracket}][{ [HTTP::header exists Content-length] and [ [HTTP::method] equals "POST" }]
Please help us to troubleshoot the issue in this code
  • Hi dude,
    I fix all missing brace... so now you will not have any errors:
    set capture 0
    if { [HTTP::header exists Content-length] and [HTTP::method] equals "POST" } {
        set capture 1
    if {$capture} {
            pool WEBRTC_POOL
        pool PUSH_POOL
