Angel_Martinez_
Apr 26, 2010Is possible to have a MQSeries Monitor ¿?
Hi
I have been reading here and also at AskF5 but I haven't found a real solution for MQSeries monitoring.
We've several Virtual Server for MQSeries and all of them are working properly with a FastL4 Profile, but the deliver is some times wrong because I only have a easy L4 TCP Monitor for the pool and the queue is stoped or just not working and of course the syn, syn-ack, ack secuence is ok.
So, is there anyone working with MQSeries + a L7 Monitor ?
Do you have any clue how to monitor from BigIP to the MQSeries Pool ?
Thank you!
BIGIP: 6800
LTM: (9.4.3 HF4 and 9.4.8 HF2)
- Angel_Martinez_
Yes I managed!
1. Add in the MQServer .ssh/authorized_keys2 the BigIP id_rsa.pub
2. cut & pastel:
[root@bigroitb:Active] .ssh cat /usr/bin/monitors/mqping.sh
!/bin/bash
MQPING=/usr/bin/dspmq
MQUSER=root
NODE_IP=$1
NODE_PORT=$2
IP=`echo $NODE_IP | sed 's/::ffff://'`
STATUS=`ssh -l $MQUSER $IP $MQPING | awk '{ print $2 }'`
case "$STATUS" in
*Running*)
echo "Up"
esac
3. Set up your monitor:
[root@bigroitb:Active] .ssh b monitor MQPING list
monitor MQPING {
defaults from external
run "mqping.sh"
4. Set up your pool:
- a TCP monitor for checking the Listener
- b MQPING monitor for checking that the queue is "Running"
[root@bigroitb:Active] .ssh b pool pool_mq list
pool pool_mq {
monitor all MQPING and tcp
members 10.64.112.109:1414
Remember, at first time ssh needs to accept the key exchange: "The authenticity of host '10.64.112.109 (10.64.112.109)' can't be established.
RSA key fingerprint is c6:d3:e4:45:9d:fe:cb:34:0c:e7:3a:6a:53:b2:26:af.
Are you sure you want to continue connecting (yes/no)?" - hoolio
Great work!
If you are more interested in usability than security, you could use a flag on ssh to ignore a change in the remote host key:
ssh -o 'StrictHostKeyChecking no' 1.1.1.1
This would make a great Codeshare example:
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/codeshare
Aaron
