Is an iRule the best way?
Hello together,
I have the following question to the specialists.
I have configured a VIP (DNS = MediaCenterOpenMedia) for http and two realserver in a pool (bcs-vpmsmcc-p1 und -p2) - works well. Now, I should redirect the request to one of my realserver and change the URL: from http://MediaCenterOpenMedia/Default.aspx?id=vpms://P7S1-PAM-PROD/VIDEO/4711 to http://bcs-vpmsmcc-p1/MediaCenterOpenMediaA/Default.aspx?id=vpms://P7S1-PAM-PROD/VIDEO/4711 ..the value 4711 is variable, will change with each request.
What is the best way?
Thanks for help
- JRahm
Admin
if the only change is the hostname and the value 4711 is not something you need to change in the redirection, then an http class (pre v11.4) or a policy (v11.4+) is the way to go.
- skettner_85430
Hi Jason,
thanks for answering. We use Version 10.1.0 - and currently no way for upgrading the system.
Any other idea?
Stefan
- What_Lies_Bene1
