trx_94323's avatar
trx_94323
Jun 02, 2014
IRules Using "LB:status" to manage traffic - round robin issue
Hello Community, Below is the set of IRules I have in place.
  Determines which pool member to route traffic too
if { ([LB::status pool www.qad.com_pool_80 member 192.168.254.189 80] eq "up") } {
     Routing to primary or fail over server
   return
    pool www.qad.com_pool_80 member 192.168.254.103 80
   return
return
I found that every few minutes traffic get's routed to the fail over server "192.168.254.103". The load balancing method used is "null" and there are 2 health monitors applied to "192.168.254.189".
/servername.txt  - Looks for string "ACTIVE" in return every 30 seconds
/erp/ - Looks for string "QAD" in return every 30 seconds
They both are green and is (should) not flagged is down unless homepage errors out or admin manually changes the txt file. I'm not sure why the "LD:status" would NOT be "up" in this test case.
Any thoughts or gotchas that I am missing?
Thanks.
Traolly Xiong
  • Disregard this post. The issue was a "return" syntax that executed before the logic code and caused the default round robin / radio load balancing method to kick in.
    Thanks.
