IRules and Domino iNotes
We have deployed an F5 and we are a lotus notes shop we are at version 10.x of the F5. How should the iRule be written?
- Vitaliy_Savrans
Nacreous
What you want to do with iRule?
- Vitaliy_Savrans
Nacreous
when HTTP_REQUEST { HTTP::respond 200 content "Hello World" "Content-Type" "text/xml" } - todonotes_11269
I want t redirect my web traffic to my domino servers and keep the same URL. For example https://IBM.com and not have it reflect my backend Domino server name information. HTTPS://IBM.com/mailservername...
Thanks in advance
- Brad_146558
I know it is possible to route to a different URI based on conditions with iRules but I think the problem is your web server on the backend.
This will more than likely break your webserver/mailserver, consider yourself warned, but you may be able to accomplish this on your web server by changing your default directory that the IP is bound to from "ibm.com" to the child folder of "ibm.com/mailservername" but I don't know anything about Lotus Notes and contacting support for Lotus to see if this is a change that can be made should be your best first step.
