rajesh1
Apr 11, 2010Irules - Help
I need some assistance in writing an irule
for the following requirement for the http requests
1)Http://xyz.com redirect to "http://www.xyz.com"
2)If all the pool members are down - redirect "http://www.xyz.com" or "http://xyz.com" to "http://www2.xyz.com"
3)If LB_Failed then fall back to "http://www2.xyz.com"
Is it recommended to have a single irule defined to match all the three requirements or 3 different irules for each requirements.
Pls provide me with an irule definitions.
Thanks, Raj
- Cspillane_18296
Hello Raj,
I haven't tested this but the following may do what you require:
if { [HTTP::uri] equals "xyz.com"} {
HTTP::redirect "http://www.xyz.com"
when LB_FAILED {
HTTP::redirect "http://www2.xyz.com"
You can probably get rid of the 'LB_FAILED' bit and just use a fallback host in the http profile instead.
let me know how you get on!
