johnko05_45751
Sep 07, 2010iRule v9 to v10 conversion
Hello, I used the iRule below just fine on version 9.4.8. We recently upgraded to 10.2. Now I get the following error in /var/log/ltm whenever this iRule is invoked:
Sep 7 23:17:41 local/tmm1 err tmm1[18638]: 01220001:3: TCL error: SSL_Header_Values_Insert - wrong args: should be "session add ssl " while executing "session add ssl [SSL::sessionid] $cert 600" clientside expression (line 3) invoked from within "clientside { set cert "SSL::cert" session add ssl [SSL::sessionid] $cert 600 set cname "SSL::cipher name" set cbits "SSL::cipher b..."
I tried playing around with the "session add ssl" line like so:
set sid "SSL::sessionid"
session add ssl $sid $cert 600
That allowed the processing to continue, however it also caused the BIGIP to panic and reboot! Below is the iRule from 9.4.8. Is there a syntax change I need to make for this to work in v10.2?
when CLIENTSSL_HANDSHAKE {
if { [SSL::cert count] > 0 } {
HTTP::release
when CLIENTSSL_CLIENTCERT {
clientside {
set cbits "SSL::cipher bits"
set cver "SSL::cipher version"
set cn [X509::subject [eval $cert 0]]
set cSSLSubject [findstr $cn "CN=" 3 ","]
set cSSLClientCert [b64encode [eval $cert 0]]
clientside {
set client_cert [session lookup ssl [SSL::sessionid]]
if { $client_cert eq ""} {
HTTP::collect
SSL::renegotiate
log local4.info "SSL session Timed out: renegotiating"
log local4.info "The page being accessed was [HTTP::uri]"
HTTP::header remove SSLSubject
HTTP::header remove SSLClientCert
HTTP::header remove SSLCipher
HTTP::header remove WebProtocol
HTTP::header remove ClientIP
HTTP::header replace ClientIP [IP::remote_addr]
if { [PROFILE::exists clientssl] == 1} {
HTTP::header replace SSLCipher [eval $cname]:[eval $cbits]-[eval $cver]
if { [eval $cert count] > 0} {
HTTP::header replace SSLSubject $cSSLSubject
HTTP::header replace SSLClientCert $cSSLClientCert
HTTP::header replace WebProtocol "HTTPS-auth"
HTTP::header replace WebProtocol "HTTPS"
log "session discarded"
discard
- johnko05_45751
I was able to fix the iRule. I changed this:
clientside {
TO THIS:
clientside {
set key [concat [SSL::sessionid] [SSL::cert 0]]
session add ssl $key 600
} - Anthony_7417Historic F5 AccountWhat I think the problem was is that, at run-time, SSL::sessionid returned null. If SSL::sessionid returns null, when the "session add" command runs, the argument is missing.
It's possible for SSL::sessionid to return null - but only in v10. In v9, instead of returning null, it would return a string of 64 zeros. See:
http://devcentral.f5.com/wiki/default.aspx/iRules/SSL__sessionid.html -- so this explains why you only ran into the problem after upgrading.
The reason it began working after your change is because you concatenated it with the client certificate -- so now it will never be null.
The better approach might be to test that SSL::sessionid returned a real value before attempting to use it in the session command. - hoolio
Hi Anthony,
Thanks for pointing this out. I wasn't aware of the change in LTM behavior. This would potentially break the v10 iRules I've written for client cert validation, so I'm glad to find out about the change.
Aaron - Anthony_7417Historic F5 AccountNo problems, hoolio!
Side note:
I noticed in your (johnko05's) rule that you would set a command-string as a variable, and then later execute it with eval:
It wasn't immediately obvious to me what problem you were trying to solve by writing the rule this way, but I'm sure it is quite deliberate. Would you mind enlightening me? - Hi every one.
