iRule to redirect users to a pool based on POST data
Gang,
I'm trying to direct a subset of my users to different pools based on their POST data. This is what I have thusfar:
if { [HTTP::method] equals "POST" } {
if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576} {
set content_length [HTTP::header "Content-Length"]
set content_length 1048576
HTTP::collect $content_length
when HTTP_REQUEST_DATA {
if { (([HTTP::payload] contains "end-user=aaaaa") or
([HTTP::payload] contains "end-user=bbbb") or
([HTTP::payload] contains "end-user=zzzzz"))} {
log local0. "User redirected"
pool A_pool
pool B_pool }
This doesn't appear to be getting me the correct end-users hitting the A_pool.
Anything glaringly apparent to this group?
Thanks.
Joe
- nitass
Employee
the irule looks okay to me.
have you run tcpdump? was there any suspicious there?
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x or host y.y.y.y and port zzz
x.x.x.x is virtual server ip
y.y.y.y is pool member ip
zzz is port number
this is my testing.[root@ve10:Active] config b virtual bar list virtual bar { snat automap destination 172.28.19.252:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { if { [HTTP::method] equals "POST" } { if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576} { set content_length [HTTP::header "Content-Length"] } else { set content_length 1048576 } HTTP::collect $content_length } } when HTTP_REQUEST_DATA { if { (([HTTP::payload] contains "end-user=aaaaa") or ([HTTP::payload] contains "end-user=bbbb") or ([HTTP::payload] contains "end-user=zzzzz"))} { log local0. "User redirected" pool A_pool } else { pool B_pool } } when HTTP_RESPONSE { log local0. "cs [IP::client_addr]:[TCP::client_port] > [clientside {IP::local_addr}]:[clientside {TCP::local_port}] ss [IP::local_addr]:[TCP::local_port] > [IP::remote_addr]:[TCP::remote_port] pool [LB::server pool]" } } [root@ve10:Active] config b pool A_pool list pool A_pool { members 200.200.200.101:80 {} } [root@ve10:Active] config b pool B_pool list pool B_pool { members 200.200.200.111:80 {} } end-user=aaaaa payload [root@ve10:Active] config curl --data "end-user=aaaaa" http://172.28.19.252/ This is 101 host. [root@ve10:Active] config cat /var/log/ltm Mar 1 17:58:46 local/tmm info tmm[22185]: Rule myrule : User redirected Mar 1 17:58:46 local/tmm info tmm[22185]: Rule myrule : cs 172.28.19.253:48674 > 172.28.19.252:80 ss 200.200.200.10:48674 > 200.200.200.101:80 pool A_pool end-user=somethingelse payload [root@ve10:Active] config curl --data "end-user=somethingelse" http://172.28.19.252/ This is 111 host. [root@ve10:Active] config cat /var/log/ltm Mar 1 18:00:11 local/tmm info tmm[22185]: Rule myrule : cs 172.28.19.253:48685 > 172.28.19.252:80 ss 200.200.200.10:48685 > 200.200.200.111:80 pool B_pool - Richie_77270
That looks like exactly what I am trying to do. Thank you very much Nitass!
