iRule to check for a post body
I am trying to look for a post body element using http::payload. I got the following iRule from internet. But the http::collect line is obstructing my page.
iRule for P2 Project
Send the data using local7 facility <190>
if { not ([HTTP::cookie exists SITESERVER] ) } {
set F2C "[string range [AES::key 128] 15 end][string range [AES::key 128] 15 end]"
HTTP::cookie insert name "F2C" value $F2C
set cookie [HTTP::header cookie]
HSL::send [HSL::open -proto UDP -pool syslog_server_pool_1] "<190> [IP::client_addr] \[[clock format [clock seconds] -format "%d/%b/%Y:%H:%M:%S %z"]\] --[IP::local_addr]--[URI::path [HTTP::uri]][URI::basename [HTTP::uri]]--QS=[HTTP::query]--C=[HTTP::header cookie]--UA=[HTTP::header User-Agent]--CT=[HTTP::header "Content-type"]"
if { [HTTP::uri] contains "landingServlet" and [HTTP::method] eq "POST" } {
HTTP::collect [HTTP::header value Content-Length]
when HTTP_RESPONSE {
if { [info exists F2C] and $F2C ne ""} {
unset -nocomplain F2C
when HTTP_REQUEST_DATA {
if { [HTTP::uri] starts_with "/airlines/landingServlet" } {
set refid "unknown"
set refclickid "unknown"
foreach x [split [string tolower [HTTP::payload]] "&"] {
if { $x starts_with "refid=" } {
set refid [lindex [split $x "="] 1]
if { $x starts_with "refclickid=" } {
set refclickid [lindex [split $x "="] 1]
HSL::send [HSL::open -proto UDP -pool syslog_server_pool_1] "<190> [IP::client_addr] \[[clock format [clock seconds] -format "%d/%b/%Y:%H:%M:%S %z"]\] --[IP::local_addr]--pbrefid=$refid--pbrefclickid=$refclickid--F2C=$F2C"
- Sriram_129909
Am I doing this correctly? - Kevin_Stewart
Employee
A few thoughts:
Make sure your request actually has a Content-Length header.
How do you know the collect command is causing the problem? Are there any specific LTM log entries?
The HTTP_REQUEST_DATA event will only fire when you issue the HTTP::collect command, so you can probably get rid of the URI check in that event.
- Sriram_129909
- I will
- I commented the line that has HTTP::Collect and the page was opening up
- I guessed so. Thanks!
- Kevin_Stewart
Employee
That may also mean the DATA event is failing. Drop some Syslog messages into each of these events and see where it's failing.
- Sriram_129909
I tried all permutations. If I uncomment HTTP::collect line, the submit on page that ends with /landingServlet fails. And yes, if I look at the iRule statistics, the HTTP_REQUEST_DATA section shows failures.
- Kevin_Stewart
Employee
Try this version with some additional logging:
when HTTP_REQUEST { Send the data using local7 facility <190> if { not ([HTTP::cookie exists SITESERVER] ) } { set F2C "[string range [AES::key 128] 15 end][string range [AES::key 128] 15 end]" HTTP::cookie insert name "F2C" value $F2C } set cookie [HTTP::header cookie] HSL::send [HSL::open -proto UDP -pool syslog_server_pool_1] "<190> [IP::client_addr] \[[clock format [clock seconds] -format "%d/%b/%Y:%H:%M:%S %z"]\] --[IP::local_addr]--[URI::path [HTTP::uri]][URI::basename [HTTP::uri]]--QS=[HTTP::query]--C=[HTTP::header cookie]--UA=[HTTP::header User-Agent]--CT=[HTTP::header "Content-type"]" if { ( [HTTP::uri] contains "landingServlet" ) and ( [HTTP::method] equals "POST" ) } { log local0. "Start collecting: [HTTP::header Content-Length]" HTTP::collect [HTTP::header Content-Length] } } when HTTP_RESPONSE { if { [info exists F2C] and $F2C ne ""} { HTTP::cookie insert name "F2C" value $F2C unset -nocomplain F2C } } when HTTP_REQUEST_DATA { log local0. "Entering Request Data event" set refid "unknown" set refclickid "unknown" foreach x [split [string tolower [HTTP::payload]] "&"] { log local0. "x = $x" if { $x starts_with "refid=" } { set refid [lindex [split $x "="] 1] log local0. "refid = $refid" } if { $x starts_with "refclickid=" } { set refclickid [lindex [split $x "="] 1] log local0. "refclickid = $refclickid" } } HSL::send [HSL::open -proto UDP -pool syslog_server_pool_1] "<190> [IP::client_addr] \[[clock format [clock seconds] -format "%d/%b/%Y:%H:%M:%S %z"]\] --[IP::local_addr]--pbrefid=$refid--pbrefclickid=$refclickid--F2C=$F2C" } - Sriram_129909
Thank you very much for working on my iRule. However I have apparently figured out another way - meaning reading off of the payload in the HTTP_REQUEST itself. The following is the iRule. This works out well for me.
when HTTP_REQUEST { Send the data using local7 facility <190> if { not ([HTTP::cookie exists SITESERVER] ) } { set F2C "[string range [AES::key 128] 15 end][string range [AES::key 128] 15 end]" HTTP::cookie insert name "F2C" value $F2C } set cookie [HTTP::header cookie] HSL::send [HSL::open -proto UDP -pool syslog_server_pool_1] "<190> [IP::client_addr] \[[clock format [clock seconds] -format "%d/%b/%Y:%H:%M:%S %z"]\] --[IP::local_addr]--NW--80--P2--[URI::path [HTTP::uri]][URI::basename [HTTP::uri]]--QS=[HTTP::query]--C=[HTTP::header cookie]--UA=[HTTP::header User-Agent]--CT=[HTTP::header "Content-type"]" if { [HTTP::uri] starts_with "/airlines/landingServlet" and [HTTP::method] eq "POST" } { set payload [HTTP::payload] set refid "unknown" set refclickid "unknown" foreach x [split [string tolower $payload] "&"] { if { $x starts_with "refid=" } { set refid [lindex [split $x "="] 1] } if { $x starts_with "refclickid=" } { set refclickid [lindex [split $x "="] 1] } } HSL::send [HSL::open -proto UDP -pool syslog_server_pool_1] "<190> [IP::client_addr] \[[clock format [clock seconds] -format "%d/%b/%Y:%H:%M:%S %z"]\] --[IP::local_addr]--NW--80--P2--pbrefid=$refid--pbrefclickid=$refclickid--C=[HTTP::header cookie]" unset payload } } when HTTP_RESPONSE { if { [info exists F2C] and $F2C ne ""} { HTTP::cookie insert name "F2C" value $F2C HTTP::cookie expires F2C 630720000 unset -nocomplain F2C } } - Kevin_Stewart
Employee
Good news. Just be aware that you're able to do this because the entire request fits inside a single TCP packet. If for whatever reason the client sends a larger packet (ie. more headers and/or larger payload data), you may find this option will miss some of the data. The HTTP::collect and subsequent HTTP_REQUEST_DATA event will buffer the request payload across TCP packets.
- Sriram_129909
Oh, that's a good catch. May I know what is the limit of payload data after which it splits it across multiple requests?
- Kevin_Stewart
Employee
There's no hard and fast rule. It depends on the network and the end points.
