danra_139044
Altostratus
Mar 25, 2014iRule: 'Switch -glob' does not work with HTTP::payload, it works using 'if-elseif' logic.
Anyway how to use 'switch -glob' to search HTTP::payload?
It works with 'if-elseif' logic.
Also, is the HTTP::release advisable to add?
if { [HTTP::method] equals "POST" }{
HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
switch -glob [HTTP::payload] {
apple {
pool apple_pool
orange {
pool orange_pool
- Kevin_Stewart
Employee
It will work, but I'm guessing you need to allow for some padding:
when HTTP_REQUEST { if { [HTTP::method] equals "POST" }{ HTTP::collect [HTTP::header Content-Length] } } when HTTP_REQUEST_DATA { switch -glob [HTTP::payload] { "*apple*" { pool apple_pool } "*orange*" { pool orange_pool } } }You shouldn't need to issue the HTTP::release command because you're explicitly defining the amount of payload to collect using the Content-Length header.
