iRule still executing for current browser session after being removed from virtual server
We're experiencing this behavior for a maintenance iRule that is frequently added to and removed from virtual servers. This primarily seems to occur when the same browser session is used. Starting a new browser session after the iRule has been removed doesn't cause the iRule to execute. Would something be getting cached, or some keep-alive property be causing this behavior? Is it expected?
Thanks.
v 11.6.0 HF4
- Walter_Kacynski
This is the behavior of iRule design as they are cached per TCP flow. This is why starting a new browser session "works" by creating a new TCP socket. To force this to clear out, you could use an
in your iRule to create a new socket for every request. Depending on your traffic volume this could cause additional load due to the increased overhead of generating new socket connections.HTTP::respond Connection close
