Irule rewrite to connect node/pool with particular path
hi Team,
Request your help for review the rule and advice.
If user access https://abc.com It should connect on back end node at https://node1.com:6443/cfcc/bclient/index.jsp/ If user access https://abc.com/cc it should connect back end node at
what i did is,created two pools, pool_6443 and pool_7443 and implemneted follwoing rule.
switch -glob [HTTP::uri] {
"/cc" {
set HTTP::uri "/cfcc/control?view=view/admin/start.jsp"
pool pool__7443
default {
pool pool_6443
somehow,this is not working.
- Amy_123193Historic F5 Account
Try using a Rewrite profile, which has similar behavior to Apache ProxyPass. You can then use the iRule just to do pool selection and pick a rewrite profile - or use an LTM Policy to select both pool and rewrite profile, which will improve performance and provide a more robust interface for configuration.
- Srini_87152
Amy, im currently using 10.x version,so cant implement with rewrite profile.. any irules can use best approch? - Amy_123193Historic F5 AccountCertainly. There is an iRule that implements ProxyPass functionality: https://devcentral.f5.com/s/articles/proxypass-v10-v11
- awilhelm
Employee
- Srini_87152
Amy, im currently using 10.x version,so cant implement with rewrite profile.. any irules can use best approch? - awilhelm
Employee
Certainly. There is an iRule that implements ProxyPass functionality: https://devcentral.f5.com/codeshare/proxypass-v10-v11
