Irule related with static content filtering with more url after suffix
Hi, when request come as /xyz/1.jpg it works perfectly and accept otherwise block. But it also blocks /xyz/1.jpg?3123123213 request. I dont want this to happen. Should i use contains with images data group or any other solution recommentdation
if {[matchclass [HTTP::uri] ends_with "images"]}
{return}
else
{reject}
- Kevin_Stewart
Employee
Does the URI start with "/xyz"? If so, you can change that "ends_with" to a "starts_with". Otherwise you migt consider a "contains" operator.
Additionally, if this is a v10 system or higher, you're better off using the class match command instead of the now deprecated matchclass.
when HTTP_REQUEST { if { [class match [stirng tolower [HTTP::uri]] starts_with images] } { return } else { reject } } - maximillean_953
uri depends on start it can be under anything. non specified.
could be ;
www.xyz.com/a/1.jpg or www.xyz.com/ads/asd/5.bmp
I try to do only allow images but at the same time accept the query after the image if there is any.
By the way i test the rule you just wrote it did not work. gives reset. i fix type btw.
also if i set url contains url might be contain .jpg ant not be the suffix of a file.
xyz.com/das/das/dasdasdasdqweqw.jpg342432423?2132131
Then contains will fail on this it will allow to pass to server.
- Kevin_Stewart
Employee
Ah, well how about this.
when HTTP_REQUEST { if { [class match [string tolower [HTTP::path]] starts_with images] } { return } else { reject } }Using the [HTTP::path] command instead to "normalize" the URI (strip off the query string value).
- maximillean_953
No it did not work either. datagroup has this records
curl -H "Host:xyz.com" http://10.10.11.11/1.jpg?1 -I curl -H "Host:xyz.com" http://10.10.11.11/1.jpg -I
when i send request response is curl: (52) Empty reply from server it rejects
- Kevin_Stewart
Employee
Typo. This works for me:
when HTTP_REQUEST { if { [class match [string tolower [HTTP::path]] ends_with images] } { return } else { reject } } - maximillean_953
Thank you Kevin best and number one as always. works both with querystrings and without and only accept the group added on data format.
Thanks again Take care and be well.
