bmoorewiz's avatar
bmoorewiz
Nov 23, 2015
iRule needs updating from HTTP_CLASS for 11.4.x
All, I was hoping someone could help me with the ASM iRule. I need the HTTP_CLASS removed as that option cannot be used on 11.4.x. I would appreciate any help in the right direction.
ltm rule block_webbots2 {
   set abort_trans 0
    Check the UA header value, set to lower case
   switch -glob [string tolower [HTTP::header User-Agent]] {
      "_googlebot_" -
      "_msnbot" -
      "_yahoo" {
          Bad UA, send a TCP reset
         set abort_trans 1
when HTTP_CLASS_SELECTED {
   if {[HTTP::class asm]==1}{
      if {$abort_trans==1}{
         ASM::disable
         reject
else
         reject
  • [POLICY::controls asm] in the HTTP_REQUEST event will tell you if asm is enabled, but I'm curious why if both conditions of if/else is to reject the request if abort_trans is 1 it matters? Can't you just reject it in the HTTP_REQUEST event without a policy check?
