Qamar_Zia_13515
Feb 08, 2017IRULE Help
Hi Folks,
Need you help to write an irule for the below requirement: HTTP request http://10.10.10.10 should be redirected to https://abc.com
Http host containing the IP address should be redirected to https with the required host name.
Regards, Qamar Zia
- Jad_Tabbara__J1
Hello Qamar,
You can use this example of code to do that.
You have to add this irule to ressources of the VS listening on 10.10.10.10:80
when HTTP_REQUEST { if { [HTTP::host] eq "10.10.10.10" } { HTTP::respond 301 noserver Location https://abc.com } }Hope that it helps
Regards
