iRule help with adding a customer header
Im trying to write an iRule for the following if response from a particular URL [] returns a 401 then to add a custom header with WWW-AUTHENTICATE with dummy value BASIC realm="USER VISIBLE REALM" or WWW-Authenticate OATH realm ="http://server.example.com/
Will the below do the job?
when HTTP_RESPONSE { if { ( [HTTP::status] eq "401" ) and ( [HTTP::header exists WWW-AUTHENTICATE] ) } {
HTTP::header replace WWW-Authenticate ""
- Leonardo_Souza
Cirrocumulus
Yes, should work.
I just tested the iRule, with small change to match my lab environment.
Headers without iRule:
HTTP/1.1 200 OK Date: Thu, 06 Apr 2017 11:16:07 GMT Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.1e-fips PHP/5.4.16 X-Powered-By: PHP/5.4.16 Set-Cookie: Chocolate=Price%3D1pound; expires=Thu, 06-Apr-2017 11:17:07 GMT Set-Cookie: Coconut=Price%3D2pounds; expires=Thu, 06-Apr-2017 11:18:07 GMT Content-Length: 503 Keep-Alive: timeout=5, max=100 Connection: Keep-Alive Content-Type: text/html; charset=UTF-8iRule:
when HTTP_RESPONSE { if { ( [HTTP::status] eq "200" ) and ( [HTTP::header exists X-Powered-By] ) } { HTTP::header replace X-Powered-By "ok" } }Headers after iRule applied to virtual server:
HTTP/1.1 200 OK Date: Thu, 06 Apr 2017 11:18:43 GMT Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.1e-fips PHP/5.4.16 X-Powered-By: ok Set-Cookie: Chocolate=Price%3D1pound; expires=Thu, 06-Apr-2017 11:19:43 GMT Set-Cookie: Coconut=Price%3D2pounds; expires=Thu, 06-Apr-2017 11:20:43 GMT Content-Length: 497 Keep-Alive: timeout=5, max=100 Connection: Keep-Alive Content-Type: text/html; charset=UTF-8
