iRule help to block traffic
Hello my intention is to block traffic from countries which are not on my safe list. So I used the below iRule
when CLIENT_ACCEPTED {
if { not([class match [whereis [IP::client_addr] country] equals allow-country]) } {
log "Dropping connection from client: [IP::client_addr], country code: [whereis [IP::client_addr]
country]"
drop
}}This works fine but when I looked at the logs I see that the internal IP's are getting dropped as well, I get that. Now I am using the below iRule to allow traffic from the allow countries and also all the internal subnets.
Rule /Common/Allow_Country_iRule : Dropping connection from client: 180.76.15.142, country code: CN
Rule /Common/Allow_Country_iRule : Dropping connection from client: 10.60.50.6, country code:
Rule /Common/Allow_Country_iRule : Dropping connection from client: 10.60.53.12, country code:I created a data group for internal subnets and am using the iRule below. It does not work. Is it the Syntax or the logic that is the issue? Can some one help? Thank you for your time in advance.
if { not([class match [whereis [IP::client_addr] country] equals allow_country]) or [IP::client_addr] equals allow_ip] )} {
log "Dropping connection from client: [IP::client_addr], country code: [whereis [IP::client_addr] country]"
drop
}4 Replies
- ekaleido
Cirrus
when CLIENT_ACCEPTED { set location [whereis [IP::client_addr]] if { [class match -value [IP::client_addr] equals allow_ip] || [class match -value $location equals allow_country] } { pool mypool } else { log "Dropping connection from client: [IP::client_addr], country code: [whereis [IP::client_addr] country]" drop } } - Domai
Altostratus
If I use "not" then its dropping the connections from the countries that are in the safe list
Rule /Common/Allow_Country_iRule : Dropping connection from client: 195.154.47.12, country code: FR
Hi Domai,
take a look to the nested iRule below. It queries [whereis [IP::client_addr] country] first and then checks if [whereis] was able to resolve a country code. If [whereis] was able to to resolve a country code it will lookup the allow-country data-group and if [whereis] was not able to resolve a country code it will lookup the allow-ip data-group. The nested approach will make sure, that only a single [wheris] and [class] execution is required for each connection attempt.
when CLIENT_ACCEPTED { if { [set whereis_result [whereis [IP::client_addr] country]] ne "" } then { if { not ( [class match $whereis_result equals "allow-country"] ) } then { log "Dropping connection from client: [IP::client_addr], country code: $whereis_result" drop } } else { if { not ( [class match [IP::client_addr] equals "allow-ip"] ) } then { log "Dropping connection from client: [IP::client_addr], country code: not available" drop } } }Cheers, Kai
- Domai
Altostratus
ltm data-group internal allow_ip { records { 10.0.0.0/8 { } 172.16.0.0/12 { } 192.168.0.0/16 { } } type ip }This is my allow_ip data group.
