Irule help needed
Hi Guys,
I have a requirement of an irule to achieve the following, will someone kindly help me out.
I have a URL http"//www.service.com/_badlink/*.pdf" i want to block this and throw a page not avaliable message will someone provide quick help here.
Regards,
when HTTP_REQUEST { if {[HTTP::host] eq "[www.service.com](http://www.service.com)" and [HTTP::uri] starts_with "/_badlink/"} { switch -glob [string tolower [HTTP::uri]] { "*.pdf" { set message "illegal file download !!!" HTTP::respond 200 content [subst -nocommands -nobackslashes [ifile get message.html]] noserver "Content-Type" "text/html" } } } }Then, you have to add an ifile containing the html content of your message. You can set $message in your content and it will be replaced by the value of the variable in irule.
- Techgeeeg
Thanks Yann can you tell me more about ifile pls also I didn't see the "_badlink" in the irule as I need to block it only for that folder.
Hello, please find below the irule reposted. The badlink is trapped here :
when HTTP_REQUEST { if {[HTTP::host] eq "www.service.com" and [HTTP::uri] starts_with "/_badlink/" } { switch -glob [string tolower [HTTP::uri]] { "*.pdf" { set message "illegal file download !!!" HTTP::respond 200 content [subst -nocommands -nobackslashes [ifile get message.html]] noserver "Content-Type" "text/html" } } } }You can create an ifile by importing your html content in System > File Management > Import ifile
Then you create an ifile object that refer to the ifile content previously imported in Local Traffic > iRules > iFile List. In the irule you refer to the ifile object created in iRules > iFile List tab
For the html content itself, it's up to you to create an html message with your own look&feel. The bonus is that you just have to set $message in the html file where you want the irule to replace this variable by the value.
