fubarSUSHI's avatar
fubarSUSHI
Mar 11, 2014
irule help: Limit HTTP Methods to ONLY GET and POST and reject everything else?
Im still trying to figure out the iRule nirvana but I am requesting the help of all y'alls to guide me in the right direction.
when RULE_INIT {
set good_http_methods [list “GET” “POST"]
    if { [class match [string tolower [HTTP::method]] contains good_http_methods] } {
        log local0. "good methods [HTTP::method]"
        return
        log local0. "rejected methods [HTTP::method]"
        reject
Or is the negative method better? (I assume it depends if you are half-glass-full vs half-glass-empty type of person?)
when RULE_INIT {
set sec_http_methods [list "CONNECT" "DELETE" "HEAD" "OPTIONS" "PUT" "TRACE"]
if { [matchclass [HTTP::method] equals $::sec_http_methods] } {
    reject
But I found this off of devcentral on ([https://devcentral.f5.com/articles/irule-security-101-02-http-methods-and-cross-site-tracing.Ux9odl5dSzQ]iRule Security 101 2.
  • You could significantly simplify the positive model like this:
        if { ( [HTTP::method] equals "GET" ) or ( [HTTP::method] equals "POST" ) } {
            return
            reject
  • Further, the class commands work on data groups not lists, so your original iRule (slightly modified):
        if { not ( [class match [HTTP::method] equals good_http_methods] ) } {
            reject
    would query a string-based data group:
    ltm data-group internal good_http_methods {
        records {
            GET { }
            POST { }
        type string
  • Kevin:
    Would this work if I wanted to log?
        if { [class match [HTTP::method] equals good_http_methods]} {
            return
            reject
    A question about setup on the data group list?
    Records>String=POST
    Records>Value=? (What do I put there?)
  • Yes that would work, though it'd be a pretty sparse log entry.
    You don't have to put anything in the data group value. We're just evaluating if the data group entry exists.
