Dave_21103's avatar
Dave_21103
May 16, 2014
iRule for URI Switching Nested Inside of Hostname Switching
Is it possible to nest URI switching inside hostname switching? If so, does someone have any links or suggestions I can try? I found a hostname switching example (below, after uri example). However, instead of switching to a pool, i would like the irule to switch to code that URI switches. Instead of "pool site1_pool" in the hostname switching example below, I would like to know if you can replace "pool site1_pool" with something similar to this:
URI switching example
switch -glob [string tolower [HTTP::uri] ] {
"/path1/file.jpg" { pool POOLNAME1 }
"/path2/file.jpg" { pool POOLNAME2 }
default { drop } } }
 Check requested host header (set to lowercase)
switch [string tolower [HTTP::host]] {
   "www.site1.com" {
      pool site1_pool
   "www.site2.com" {
      pool site2_pool
   default {
      pool default_pool
  • Absolutely possible.
            "www.domain.com" {
                switch -glob [string tolower [HTTP::uri]] {
                    "/app1*" { log local0. "app1" }
                    "/app2*" { log local0. "app2" }
                    "/app3*" { log local0. "app3" }
                    default { drop }
            default {
                drop
