irule for URI based redirection to separate Pools
Hi, I am new to irules. Need help in writing an irule that does a simple URI re-direction to seperate Pools with NO default Pool on the VS and the F5 returns a default-http page guiding to the user to use the exact uri/wsdl page. Something like - /dev goes to Pool-dev /ct goes to Pool-ct /uat goes to Pool-uat and the response for the default-URL (without any uri) is returned by the F5 saying "for dev use /dev?wsdl and so on...."
Please advise?
- sandy16
Altostratus
Just to add, i am running 11.5.1 HF3 on the 5250v platform. - cjunior
Nacreous
Maybe you can do like that:
when HTTP_REQUEST { set path [string tolower [lindex [split [HTTP::path] "/"] 1]] switch -glob $path { "dev" { pool pool-dev } "ct" { pool pool-ct } "uat" { pool pool-uat } default { HTTP::respond 200 content "Content-Type "text/html" Connection Close" } } }You can get an iFile or base64 variable content to present the html too. Find some examples in this channel.
Regards.
- sandy16
Altostratus
thanks, can you please shed some light on this irule? what does set path, string tolower, lindex, split, switch -glob variables do?
- cjunior
Nacreous
You can find a good documentation of iRule events tips and tricks in this link: https://devcentral.f5.com/articles/irules-101-04-switch
I will try to be clear, here we go:
This event triggers in http request when HTTP_REQUEST { this will store the first http path segment in lower case so, we'll define the request traffic direction as needed example: request for url: http://mywebservice.com/DEV/service [HTTP::host] ==> mywebservice.com (not used, just to understand) [HTTP::path] ==> /DEV/service [split [HTTP::path] "/"] ==> [split /DEV/service "/"] ==> { DEV service} [lindex { DEV service} 1] ==> DEV [string tolower {DEV}] ==> dev (this is useful when web service is case insensitive (windows eg)) set path ==> stores the value "dev" set path [string tolower [lindex [split [HTTP::path] "/"] 1]] this will verify the value stored in path variable switch -glob $path { case value is "dev", request goes to the pool-dev "dev" { pool pool-dev } case value is "ct", request goes to the pool-ct "ct" { pool pool-ct } case value is "uat", request goes to the pool-uat "uat" { pool pool-uat } otherwise, show the help page default { here we will write the response content page HTTP::respond 200 content "`Available resource options````
