Junzo's avatar
Junzo
4 years ago
iRule for sorry page and Maintenance page
Hi
Implemented 2 iRule to 1 Virtual Server.
Sorry.html and Maintenance.html page.
Both are working properly individually.
case1: server down -> sorry.html
case2: maintenance time -> maintenance.html
However, during the Maintenance period, once the server is down, no page show. just IE error "This page can't be displayed".
case3: maintenance time and server down -> (Expect) maintenance.html -> (result) IE error.
Can I get any suggestions? configuration or iRules.
iRule 1
 set maintenance_start_time "0000";
 set maintenance_end_time "2359";
 set maintenance_day "Sunday";
 scan [clock format [clock seconds] -format {%A %k %M}] {%s %s %s} cur_day cur_hour cur_minute
 set cur_time ${cur_hour}${cur_minute}
if { ($cur_day eq $maintenance_day) &&
 ($cur_time >= $maintenance_start_time) &&
 ($cur_time <= $maintenance_end_time) } {
  HTTP::respond 200 ifile "/Common/maintenance.html"
iRule 2
 if { [active_members Pool_A] < 1 } {
 HTTP::respond 200 ifile "/Common/sorry.html"
Best Regards
  • Hello Junzo,
    Try this:
    when LB_FAILED {
    • Junzo's avatar
      Junzo
      Thank you for your suggestion.
      still doesn't work.. I try another iRule.
  • This is expected behaviour, as there are 2 matches for HTTP::respond event when server goes down during the scheduled maintenance. This will cause TCL error with multiple redirects and cause reset (RST) to the connection. You can combine both iRules in one and give SORRY page only when server is down out of maintenace window.
     set maintenance 1
      set maintenance 0
      return
    when LB_FAILED {
    if { ([active_members Pool_A] < 1) and ($maintenance == 0) } {
      #log local0. "scheduled maintenance going on. no sorry page"
  • I thought of another idea of using event disable command to stop executing other iRules if maintenance page iRule is triggered. Use higher priority for sorry page iRule or move it to the top.
    when HTTP_REQUEST priority 100  {
     event disable all
  • Junzo's avatar
    Junzo
    Hi SanjayP,
    Thank you for your suggestions! let me test and share the rusult here soon.
