John_McInnes_44's avatar
John_McInnes_44
May 23, 2006
iRule for SNATing pool traffic to Virtual
Background:
All my pools have forwarding Virtual server's in and outbound because the pool members use real IP addresses. This is probably a kind of rare setup these days.
I run a Virtual for SMTP, for hosting 1000's of customer domains. Occaisionally a pool member will need to talk back to the Virtual. Usually this is when two customers send each other email.
Problem:
The pool members can't connect to the Virtual server of which it is a member in an IP forwarding environment.
Solution:
Apply this iRule to the Virtual. It will SNAT your Pool members when they try to connect to the Virtual.
when CLIENT_ACCEPTED {
  if { ( [matchclass [IP::remote_addr] equals $::DATAGROUP ] ) and ( [IP::addr [IP::local_addr] equals "virtual.ip.address"] ) }
    log "Automapping [IP::remote_addr] -> [IP::local_addr]"
    snat automap
  else
    log "Not Automapping [IP::remote_addr] -> [IP::local_addr]"
Where DATAGROUP is the name of a Data Group that contains the Pool subnet.
Hope it helps someone, as I searched here and didn't find anything that was specifically to solve this problem. Tested on LTM 3400 running 9.2.
