irule for selecting the same pool for multiple vips
I have two virtual servers ans both are pointing to same single server (pool member) with same port like 10.10.10.10:8888. so i need a irule to select the these pool member. please suggest. thank you
- nitass
Employee
is match across for persistence usable?
sol5837: Match Across options for session persistence
https://support.f5.com/kb/en-us/solutions/public/5000/800/sol5837.html- sudarshan_cheru
Altostratus
yes i am having source persistence. i can use "Match Across Pools" but i dont want to differentiate with URI like { [HTTP::uri] starts_with "/a". i need if the connection hitting vip it should point to the irule pool and same to another vip should point the same irule pool
- nitass_89166
Noctilucent
Altostratus
- nitass
Employee
you mean example in sol5837, don't you? it is just an example (you do not need it).
- sudarshan_cheru
Altostratus
ok.. can i have some thing like this when CLIENT_ACCEPTED { set DEFAULT_POOL [LB::server pool] } - nitass
Employee
i think you do not need irule at all. just persistence profile with match across option could be enough. - sudarshan_cheru
Altostratus
yes nitass its good. we no need to go for irule. suggested as create pool for individual vip and mention the pool member. its like below vip name : atm.aaa.com-80-vip vip IP : 20.20.20.20:80 pool : atm_pool member : 10.10.10.10:8888 vip name : atm.aaa.com-8888-vip vip IP : 20.20.20.20:8888 pool : atm_pool member : 10.10.10.10:8888
- nitass_89166
Noctilucent
- sudarshan_cheru
Altostratus
ok.. can i have some thing like this when CLIENT_ACCEPTED { set DEFAULT_POOL [LB::server pool] } - nitass_89166
Noctilucent
Altostratus
