Kannan_Thalaia1
Cirrus
Nov 13, 2015Irule for pool selection base on cookie presence
Hello,
I wish to do pool selection base on cookie presence.
The logic is simple, if any http request come with a specific cookie ( like JSESSIONID) it need to go to a pool, otherwise it need to go to another pool.
Any help be appreciated.
Regards, Kannan.
- Kevin_Davies_40
Nacreous
when HTTP_REQUEST { if {[HTTP::cookie exists {JSESSIONID}]} { pool mypool } } - Brad_Parker
Cirrus
If you are looking to choose a pool juts on the presence of a cookie this should do the trick. It will require an HTTP profile. If your app is HTTPS it will also require a client SSL profile:
when HTTP_REQUEST { if {[HTTP::cookie exists "JSESSIONID"]}{ pool poolA } else { pool poolB } }
