Geoff_34657
Mar 28, 2019Irule for pool direction
I have an irule that works properly in Edge and in Chrome but, fails in IE. I am not sure why though. My logs say it's the same request but, IE gives a 404 page cannot be found error.
set my_uri [string tolower [HTTP::uri]]
set my_host [string tolower [HTTP::host]]
if { $my_uri contains "/core/" } {
pool Enterprise_Search_POC.11040
log local0. "Directing core port for CORE: $my_host $my_uri "
} if { $my_uri contains "/api/" } {
log local0. "Directing core port for API : $my_host $my_uri "
- Juraj
Cirrus
when HTTP_REQUEST { switch -glob -- [string tolower [HTTP::path]] { "*/core/*" { pool Enterprise_Search_POC.11040 log local0. "Directing core port for CORE: [HTTP::host] [HTTP::uri] " } "*/api/*" { pool Enterprise_Search_POC.11040 log local0. "Directing core port for API : [HTTP::host] [HTTP::uri] " } default { pool some_defaut_pool } } }Not sure if typo, but in both cases you have the same pool.
